Using JMP > JMP Reports > Add Images to a JMP Graph or Report > Paste an Image at the End of a JMP Report
Publication date: 04/21/2023
You can add a graphic to the end of a JMP report window. Copy the graphic from a graphics program onto your computer’s clipboard, display the report window, and select Edit > Paste.
