Predictive and Specialized Modeling > Predictor Screening > Predictor Screening Platform Options
Publication date: 04/21/2023
The Predictor Screening red triangle menu has the following options:
Save Results
Saves the predictor ranking table from the report to a new data table.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
