Publication date: 04/21/2023
Project Contents
In a self-contained JMP project, any files you save to the project contents appear in the Contents tool pane.
Tip: To hide or show the Contents tool pane, select Project > Show Contents. To specify which tool panes appear by default when you create a project, select File > Preferences > Projects and choose the initial tool panes.
Open a file from the project contents
In the Contents tool pane, double-click a file.
Create a folder in the project contents
1. Click the Contents red triangle menu and select New Folder.
2. Name the folder and click OK.
Move files into folders
In the Contents tool pane, drag a file into a folder.
Copy a file or folder from your computer into the project contents
1. Click the Contents red triangle menu and select Copy Files into Project or Copy Folder into Project.
2. Navigate to the file or folder and click Copy into Project.
Copy a file from your project contents to your computer
1. In the Contents tool pane, right-click a file and select Copy File As.
2. Click Browse and navigate to where you want to save the file.
3. Click Save.
Rename a file in the project contents
In the Contents tool pane, right-click a file and select Rename.
Delete a file in the project contents
In the Contents tool pane, right-click a file and select Delete.
