Design of Experiments Guide > Prospective Sample Size and Power
Publication date: 04/21/2023
The Sample Size and Power platform is deprecated, meaning it is an older platform that contains features that can be accessed in a newer platform. This legacy platform might not be available in future releases of JMP. Sample size and power calculators are now available in the Sample Size Explorers platform. Select DOE > Sample Size Explorers for sample size calculations.
For sample size and power calculators see “Sample Size Explorers”.
Contents
Launch the Sample Size and Power Platform
One Sample Mean Calculator
One Sample Mean Calculator Fields
Two Sample Means Calculator
Two Sample Means Calculator Fields
k Sample Means Calculator
k Sample Means Calculator Fields
One Sample Standard Deviation Calculator
One Sample Standard Deviation Calculator Fields
One Sample Proportion Calculator
One Sample Proportion Calculator Fields
Two Sample Proportions Calculator
Two Sample Proportions Calculator Fields
Counts per Unit Calculator
Sigma Quality Level Calculator
Sigma Quality Level Calculator Fields
Reliability Test Plan Calculator
Reliability Test Plan Calculator Fields
Reliability Demonstration Calculator
Reliability Demonstration Calculator Fields
