Basic Analysis > Text Explorer > Text Explorer Platform Options > Report Options in Text Explorer
Publication date: 04/21/2023
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
