Publication date: 04/21/2023
Sample Data Tables
All of the examples in the JMP documentation suite use sample data. Select Help > Sample Data Folder to open the sample data directory.
To view an alphabetized list of sample data tables or view sample data within categories, select Help > Sample Index.
Sample data tables are installed in the following directory:
On Windows: C:\Program Files\SAS\JMP\17\Samples\Data
On macOS: \Library\Application Support\JMP\17\Samples\Data
In JMP Pro, sample data is installed in the JMPPRO (rather than JMP) directory.
To view examples using sample data, select Help > Sample Index and navigate to the Teaching Resources section.
