Basic Analysis > Simulate
Publication date: 04/21/2023
Simulate
Answer Challenging Questions with Parametric Resampling
The Simulate feature provides powerful parametric and nonparametric simulation capability. Use Simulate to do the following:
Expand on the bootstrap to provide parametric bootstrapping.
Obtain power calculations in nonstandard situations.
Approximate the distribution of statistics, such as predicted values, and confidence intervals, in nonstandard situations.
Conduct permutation tests.
Explore the effect of assumptions about predictors on models.
Explore various “what if” scenarios relative to your models.
Evaluate new or existing statistical methods.
The Simulate feature is available in many reports, including all of those that support Bootstrap. To access Simulate, right-click in a report.
Figure 10.1 Power Analysis Using Simulate
Contents
Overview of the Simulate Feature
Example of the Simulate Feature
Launch the Simulate Feature
The Simulate Window
The Simulate Results Table
Simulation Results Report
Simulated Power Report
Additional Examples of the Simulate Feature
Example of a Permutation Test
Example of Retaining a Factor in Generalized Regression
Example of a Prospective Power Analysis
