Publication date: 04/21/2023
Image shown hereThe Naive Bayes Report
By default, the Naive Bayes report contains reports for fit details, the response column, the Confusion Matrix report, and the ROC and Lift curves.
Figure 8.7 Naive Bayes ReportĀ
Naive Bayes Report
Image shown hereFit Details Report
The Fit Details report in the Naive Bayes platform shows various measures of fit for the model for the Training set, and for the Validation and Test sets if they are specified. The Measure column lists the different fit statistics and the Definition column shows the formulas for the corresponding fit statistics. See Measures of Fit for Categorical Responses. By default, the Fit Details report in the Naive Bayes report window is closed.
Image shown hereResponse Column Report
In the Naive Bayes platform, the report for the response column is named after the column name of the response. The report shows performance statistics for the naive Bayes classification in a summary table for the Training set, and the Validation and Test sets if they are specified. The summary tables contain the following columns:
Count
The number of observations in the set corresponding to the table (Training, Validation, or Test set).
Misclassification Rate
Proportion of observations in the corresponding set that are misclassified by the model. This is calculated as Misclassifications divided by Count.
Misclassifications
The number of observations in the corresponding set that are classified incorrectly.
Image shown hereConfusion Matrix Report
The Confusion Matrix report in the Naive Bayes platform shows a confusion matrix and a confusion rates matrix for the Training set, and for the Validation and Test sets if they are specified. A confusion matrix is a two-way classification of actual and predicted responses. A confusion rates matrix is equal to the confusion matrix, with the numbers divided by the row totals.
Image shown hereROC Curves
The report displays the Receiver Operating Characteristic (ROC) curve for the Training set, and for the Validation and Test sets if they are specified. The ROC curve measures the ability of the fitted probabilities to classify response levels correctly. The further the curve from the diagonal, the better the fit. An introduction to ROC curves is found in ROC Curves in Basic Analysis.
See ROC Curve for more information about ROC curves.
