You can manually move or rescale the axis coordinates on a 3D scatterplot by clicking and dragging the axis. This option shows a different set of coordinates on the 3D scatterplot. It also lets you change the space displayed between the coordinates (or the coordinate scaling).
You can also specify axis properties by double-clicking the axis and modifying settings in the specifications window.
1. Hover over the middle of the axis.
2. Click and drag the axis.
1. Hover over the end of the axis.
1. Hover over the middle of the axis (the axis, not the label).
2. Double-click the axis.
3. Change the minimum and maximum coordinate values.
3. Click to deselect the Labels option for major or minor axes.
For more information about updating axes, see Customize Axes and Axis Labels in Graphs and Extend Divider Lines and Frames for Categorical Axes in Using JMP.
