In the JMP Formula Editor, you can build formulas that calculate probabilities and quantiles for statistical distributions including the binomial, beta binomial, negative binomial, poisson, gamma poisson, and hypergeometric distributions. See Discrete Probability Functions in the JSL Syntax Reference for more information about distribution parameterizations and function arguments.
For information about the syntax for the Beta Binomial Distribution function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Beta Binomial Probability function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Beta Binomial Quantile function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Binomial Distribution function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Binomial Probability function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Binomial Quantile function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Gamma Poisson Distribution function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Gamma Poisson Probability function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Gamma Poisson Quantile function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Hypergeometric Distribution function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Hypergeometric Probability function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Neg Binomial Distribution function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Neg Binomial Probability function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Poisson Distribution function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Poisson Probability function, see Discrete Probability Functions in the JSL Syntax Reference.
For information about the syntax for the Poisson Quantile function, see Discrete Probability Functions in the JSL Syntax Reference.
