The Fit Response Screening red triangle menu contains options to save the calculated data.
Effect Tests
Shows or hides the Effect Tests table. See Effect Tests Table.
Effect Plots
Shows or hides the FDR PValue Plot for Effects and the FDR Logworth by Effect Size plot.
Overall Report
Shows or hides the Overall Fit table, which contains a row for each Y variable. For each Y, the columns in the table summarize information about the model fit. If you select the Robust Fit option on the launch window, the models are fit using Huber M-estimation. The table contains the following columns:
Y
The specified response columns.
RSquare
The multiple correlation coefficient.
RMSE
The Root Mean Square Error.
Count
The number of observations (or sum of the Weight variable).
Overall FRatio
The test statistic for model fit from the Analysis of Variance report in Least Squares Fit.
Overall PValue
The p-value for the overall test of model significance.
Overall Logworth
The logworth of the p-value for the overall test of model significance.
Overall FDR PValue
The overall p-value adjusted for the false discovery rate. (See The Response Screening Report.)
Overall FDR Logworth
The logworth of the Overall FDR PValue.
Overall Rank Fraction
(Not shown by default.) The rank of the Overall FDR Logworth expressed as a fraction of the number of tests. If the number of tests is m, the largest Overall FDR Logworth value has Rank Fraction 1/m, and the smallest has Rank Fraction 1.
Overall Plots
Shows or hides the Overall FDR PValue Plot and the FDR Logworth by RSquare plot.
Select Effects Where
Opens the Select Where window. You can select specific responses in the Effects Tests table that correspond to a particular condition by using the Comparison menu and Value text box. For example, you can select all effects such that Effect Size > 0.80. After you click OK, the responses are selected in the Result Table.
Tip: You can also access the Select Where window by right-clicking anywhere in the Effect Tests table.
Select Responses for Selected Effects
Selects response columns in the original data table that correspond to the selected effects in the Effect Tests table.
Save Effect Tests
Saves the Effect Tests table to a new data table. The Effect Tests data table contains a table variable called Original Data that gives the name of the data table that was used for the analysis. If you specified a By variable the Original Data variable also gives the By variable and its level.
Save Overall Fit
Saves the Overall Fit table to a new data table. The Overall Fit data table contains a table variable called Original Data that gives the name of the data table that was used for the analysis. If you specified a By variable the Original Data variable also gives the By variable and its level.
Save Estimates
Opens a data table in which each row corresponds to a response and the columns correspond to the model terms. The entries are the parameter estimates obtained by fitting the specified model. This data table also contains a table variable called Original Data that gives the name of the data table that was used for the analysis. If you specified a By variable, JMP creates an estimates table for each level of the By variable, and the Original Data variable gives the By variable and its level.
Save Prediction Formula
Adds columns to the original data table containing prediction equations for all responses.
Save Least Squares Means
Opens a data table where each row corresponds to a response and a combination of effect settings. The row contains the least squares mean and standard error for that combination of settings.
Model Dialog
Opens a window containing the model dialog that you have run to obtain the given report.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
