The Generalized Regression red triangle menu contains the following options:
Model Dialog
Shows the completed Fit Model launch window for the current analysis.
Set Random Seed
Sets the seed for the randomization process that is used for KFold and Holdback validation. This is useful if you want to reproduce an analysis. Set the seed to a positive value, save the script, and the seed is automatically saved in the script. Running the script always produces the same cross validation analysis.
Save Coding Table
Creates a new data table whose first columns show the JMP coding for all model parameters. The last column shows the values of the response variable. If you specified a sample size column for a binomial response, both the response and sample size columns are shown in the table. If you used two response columns to specify censoring, both response columns are shown in the table. If you used a response column that contains a Detection Limits column property to specify censoring, the response column in the coding table contains a Detection Limits column property.
Note: The coding data table contains a table variable called Original Data that gives the name of the data table that was used for the analysis. In the case where a By variable is specified, the Original Data table variable also gives the By variable and its level.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
