The Make Validation Column platform is available only in JMP Pro.
Validation is the process of using part of a data set to estimate model parameters and using another part to assess the predictive ability of a model. You can partition the data into two or three sets or create four or more categories for K-Fold crossvalidation. The Make Validation Column platform provides several different methods to create these partitions.
