The Parallel Plot red triangle menu provides the following options:
Show Reversing Checkboxes
Reverses the scale for one or more variables.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
For more information about the context menu options that appear when you right-click a parallel plot, see Using JMP.
