If you find yourself doing the same steps over and over in JMP, capture your workflow with Workflow Builder. It is like an advanced macro that records your actions in JMP so that you can replay them or share them with others.
Here are some situations where you might use Workflow Builder:
– If you are repeating steps in JMP, like preparing data or making the same graphs
– If you want to teach JMP to others
– If you need a complete log of what you are working on to meet industry requirements
