If you are not sure where to find a statistical procedure, do a search across JMP. Results are tailored to the window that you launch the search from, such as a data table or report.
1. Click Help > Search JMP. Or, press Ctrl+comma.
2. Enter your search text.
3. Click the result that contains the procedure that you want.
On the right, you can see a description and the location of the procedure.
4. Click the corresponding button to open or go to a result.
