In a JMP bubble plot, click a bubble to select it. Note the following:
• Visually, selected bubbles become darker or brighter, and non-selected bubbles are more transparent.
• If the bubble was not filled initially, selection fills it.
• If no bubbles are selected, all of the bubbles are semi-transparent.
When you select a bubble, all of the rows in the data table that correspond to the selected bubble are highlighted. Note the following:
• If the bubble is an aggregate based on an ID column, all of the rows for that ID are highlighted. Otherwise, the one row represented by that bubble is highlighted.
• If you specify an ID and a Time variable, selecting a bubble highlights all of the rows for that ID, across all of the Time levels.
If you select a row from the data table, it is selected in the associated bubble plot. Note the following:
• If you have not specified a Time variable, selecting one row from the data table highlights the corresponding bubble in the plot.
• If you have specified a Time variable, selecting one row from the data table highlights the corresponding bubble for only that time period in the dynamic bubble plot.
