The Ternary Plot red triangle menu contains options to modify the plot.
Note: To view more detailed options, right-click the plot.
Show Constraints
Shows or hides the constraints on the plot. The default plot shows the constraints.
Contour Fill
Allows filling of contours if a contour formula is specified in the plot. You can select Lines Only, Fill Above, or Fill Below. The default platform shows lines only.
Color Theme
Allows you to select a color theme. The default plot shows the Blue to Gray to Red color theme.
Show Points
Shows or hides the plotted points. The default plot shows the points.
Fit to Window
Specifies whether the graph is resized as you resize the JMP window. The default setting is Auto, which is usually set to On except when the window is shared with other content. To always fit the graph inside the window, keep the setting at On. You can also maintain the aspect ratio. To prevent the graph from resizing, change the setting to Off.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Save Platform Preferences, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
