The Workflow Builder is a JMP utility to capture, build, manage, and share data preparation and analysis workflows. The Workflow Builder uses the Enhanced Log to capture actions as you work in JMP. Use the Workflow Builder to do any of these actions:
• automate a workflow
• share a workflow
• re-run a sequence of steps with new data
• archive or document an analysis
Figure 12.1 Workflow Builder
