This section contains additional examples using the Simulate feature.
• Example of a Permutation Test
• Example of Retaining a Factor in Generalized Regression
• Example of a Prospective Power Analysis
For an example that shows how to simulate a confidence interval for Ppk and the percent nonconforming for a nonnormal variable, see “Example of the Simulation of Confidence Limits for a Nonnormal Process Ppk” in Quality and Process Methods.
