Publication date: 07/24/2024
Color Legend
Several of the Design Evaluation sections show values colored according to a color gradient. The colors are applied to diagnostic measures to help you identify the values that reflect good or bad design properties. You can edit the legend to adjust the color definitions.
Figure 17.10 Color LegendĀ
Color Legend
You can modify the color legend using the options in the section red triangle menu or by right-clicking the color legend.
Show Legend Values
Shows or hides the values that appear under the color legend.
Edit Legend Values
Specify the values that define the color gradient.
