Here are pictures of many of the graphs that you can create with JMP. Each picture is labeled with the platform used to create it.
Histogram Analyze > Distribution |
Bivariate Analyze > Fit Y by X |
Oneway Analyze > Fit Y by X |
Oneway t Test Analyze > Fit Y by X |
Logistic Analyze > Fit Y by X |
Mosaic Plot Analyze > Fit Y by X |
Matched Pairs Analyze > Specialized Modeling > Matched Pairs |
Leverage Plot Analyze > Fit Model |
LS Means Plot Analyze > Fit Model |
MANOVA Analyze > Fit Model |
Partition Analyze > Predictive Modeling > Partition |
Neural Diagram Analyze > Predictive Modeling > Neural |
Actual by Predicted Analyze > Predictive Modeling > Model Comparison |
Nonlinear Fit Analyze > Specialized Modeling > Nonlinear |
Surface Profiler Analyze > Specialized Modeling > Gaussian Process |
Time Series Analyze > Specialized Modeling > Time Series |
Screening Analyze > Specialized Modeling > Specialized DOE Models > Fit Two Level Screening |
FDR pValue Plot Analyze > Screening > Response Screening |
Scatterplot Matrix Analyze > Multivariate Methods > Multivariate |
Dendrogram Analyze > Clustering > Hierarchical Cluster |
Self Organizing Map Analyze > Clustering > K Means Cluster |
Principal Components Analyze > Multivariate Methods > Principal Components |
Canonical Plot Analyze > Multivariate Methods > Discriminant |
Loadings Plot Analyze > Multivariate Methods > Partial Least Squares |
XBar and R Charts Analyze > Quality and Process > Control Chart Builder |
Average Chart Analyze > Quality and Process > Measurement Systems Analysis |
Variability Chart Analyze > Quality and Process > Variability/Attribute Chart |
Goal Plot Analyze > Quality and Process > Process Capability |
Individual Measurement Chart Moving Range Chart Analyze > Quality and Process > Control Chart > IR |
XBar Chart Analyze > Quality and Process > Control Chart > XBar |
Pareto Plot Analyze > Quality and Process > Pareto Plot |
Ishikawa Chart Fishbone Chart Analyze > Quality and Process> Diagram |
Compare Distributions Analyze > Reliability and Survival > Life Distribution |
Nonparametric Overlay Analyze > Reliability and Survival > Fit Life by X |
Scatterplot Analyze > Reliability and Survival > Fit Life by X |
MCF Plot Analyze > Reliability and Survival > Recurrence Analysis |
Overlay Analyze > Reliability and Survival > Degradation |
Prediction Interval Analyze > Reliability and Survival > Destructive Degradation |
Forecast Analyze > Reliability and Survival > Reliability Forecast |
Piecewise Weibull NHPP Analyze > Reliability and Survival > Reliability Growth |
Reliability Block Diagram Analyze > Reliability and Survival > Reliability Block Diagram |
Failure Plot Analyze > Reliability and Survival > Survival |
Survival Quantiles Analyze > Reliability and Survival > Fit Parametric Survival |
Baseline Survival Analyze > Reliability and Survival > Fit Proportional Hazards |
Mixture Profiler Analyze > Consumer Research > Categorical |
Factor Loading Plot Analyze > Multivariate Methods > Factor Analysis |
Prediction Profile Analyze > Consumer Research > Choice |
Characteristic Curves Analyze > Multivariate Methods > Item Analysis |
Multiple Correspondence Analysis Analyze > Multivariate Methods > Multiple Correspondence Analysis |
Uplift Model Analyze > Consumer Research > Uplift |
Dual Plot Analyze > Multivariate Methods > Item Analysis |
Line Graphs Graph > Graph Builder |
Box Plots Graph > Graph Builder |
Stacked Bar Chart Graph > Graph Builder |
Pie Chart Graph > Graph Builder |
Needle and Line Chart Graph > Graph Builder |
Smoother Graph > Graph Builder |
Three Dimensional Scatterplot Graph > Scatterplot 3D |
Contour Plot Graph > Graph Builder |
Bubble Plot Graph > Bubble Plot |
Parallel Plot Graph > Graph Builder |
Cell Plot Graph > Cell Plot |
Treemap Graph > Graph Builder |
Scatterplot Matrix Graph > Scatterplot Matrix |
Ternary Plot Graph > Ternary Plot |
Prediction Profiler Graph > Profiler |
Contour Profiler Graph > Contour Profiler |
Surface Plot Graph > Surface Plot |
Mixture Profiler Graph > Mixture Profiler |
Multidimensional Scaling Analyze > Multivariate Methods > Multidimensional Scaling |
MaxDiff Analyze > Consumer Research > MaxDiff |
Stress Patterns Plot Analyze > Reliability and Survival > Cumulative Damage |
Repairable Systems Simulation Analyze > Reliability and Survival > Repairable Systems Simulation |
Latent Class Analysis Analyze > Clustering > Latent Class Analysis |
Predictor Screening Analyze > Screening > Predictor Screening |
Process Screening Analyze > Quality and Process > Process Screening |
Text Explorer Analyze > Text Explorer |
Multiple Factor Analysis Analyze > Consumer Research > Multiple Factor Analysis |
Model Driven Multivariate Control Chart Analyze > Quality and Process > Model Driven Multivariate Control Chart |
Structural Equation Models Analyze > Multivariate Methods > Structural Equation Models |
Support Vector Machines Analyze > Predictive Modeling > Support Vector Machines |
