If your organization has purchased JMP Live, you can:
• Publish reports to JMP Live. See “Share Reports to JMP Live”.
• Publish data tables to JMP Live. See “Share Data to JMP Live”.
• Access the JMP Live installation help at https://www.jmp.com/support/help/en/18.1/jmplive/jmpliveinstall.shtml.
• Access the JMP Live user help at https://www.jmp.com/support/help/en/18.1/jmplive/jmplive.shtml.
• Access the JMP Live administrator help at https://www.jmp.com/support/help/en/18.1/jmplive/jmpliveadmin.shtml.
• Use the JMP Scripting Language to publish reports or data to JMP Live. See “Publish Reports or Data to JMP Live”.
