The Life Distribution Profilers section of the Bayesian Estimates report in the Repeated Measures Degradation platform contains results of simulated realizations from the posterior samples that were generated by the MCMC procedure. There is a summary of the settings that were used for the simulated realizations, as well as profilers for the failure distribution and the quantile. You can use these profilers to make inferences about the failure probabilities over time or about the time at which a certain probability of failures will occur. For more information about profilers and their options, see “Profiler” in Profilers.
Tip: To change the settings for the simulated realizations, select the Change Life Distribution Profilers option from the Bayesian Estimates <N> red triangle menu.
