Multivariate Methods > Multidimensional Scaling > Multidimensional Scaling Platform Options
Publication date: 07/24/2024
The Multidimensional Scaling red triangle menu options give you the ability to customize reports according to your needs. The options available are determined by the type of data and the number of dimensions that you use for your analysis.
MDS Plot
Shows or hides the MDS Plot.
Diagnostics
Provides diagnostics for the MDS.
Shepard Diagram
Shows a plot of actual proximity (or transformed proximity if a transformation is used) versus the predicted proximity. This report appears by default. See Shepard Diagram.
Waern Links
Displays the Waern links on the MDS plot. Controls for the portion (smallest or largest) are available when this option is selected. See Waern Links.
Show Coordinates
Provides a report of the solution coordinates. These are the coordinates of the points on the Multidimensional Scaling Plot. The report shows the coordinates of up to three dimensions. Right-click in the report and select Columns to add additional dimensions to the report. The maximum number of dimensions is the number of dimensions set in the launch window.
Show Proximity
Provides a report of the proximities. The original and derived proximities (distances) are provided between each pair of objects. The pairs are identified in the From and To object columns. If a transformation was used, the transformed proximities are also included in the table.
Save Proximity
(Available only if Attribute List is the data format.) Saves the distance matrix to the data table.
3D Plot
(Available only if three or more dimensions are specified for Set Dimensions in the launch window.) Shows a 3-D plot of the first three dimensions.
Save Coordinates
Saves the solution coordinates to the data table in separate columns.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
