In the Pareto Plot platform, the Plots red triangle menu contains options to customize the appearance of the plots.
Pareto
Shows a submenu of options to change the appearance of the Pareto plot.
Show Pareto Bars
Shows or hides the bars that correspond to the value for each cause.
Subcategory Bar Style
(Available only when a subcategory is specified in the launch window.) Sets the style of the Pareto bars to Side by Side, Stacked, Bullet, Nested, Single, Needle, or Float.
Bar Style
(Not available when a subcategory is specified in the launch window.) Sets the style of the Pareto bars to Bar or Float.
Bar Label Format
Opens a window that enables you to edit the format of the bar label.
Show Pareto Line
Shows or hides a line that connects the values for each cause.
Pareto Line Connect Style
(Available only when the Pareto Line is shown in the plot.) Sets the line style of the Pareto line to Line, Curve, or Step.
Show Pareto Markers
Shows or hides markers at the value for each cause.
Show Error Bars
Shows or hides error bars on the Pareto bars.
Pie Chart
Shows the bars as a pie chart.
Cumulative Percent
Shows a submenu of options that affect the appearance of the cumulative percent curve and labels on the Pareto plot.
Show Cum Percent Curve
Shows or hides the cumulative percent curve above the bars.
Cum Line Connect Style
Sets the line style of the cumulative percent curve to Line, Curve, or Step.
Cum Percent Curve Color
Changes the color of the cumulative percent curve.
Show Cum Percent Points
Shows or hides the points on the cumulative percent curve.
Label Cum Percent Points
Shows or hides the labels for the points on the cumulative curve.
Cum Percent Label Format
Shows a window that enables you to edit the format of the cumulative percent label.
Orientation
Sets the orientation of the plot to be vertical or horizontal. The default orientation is vertical.
Note: When the orientation is horizontal, the scale of the X axis is always percent. The Percent Scale option that enables you to toggle between a percent scale and a count scale is disabled.
Legend Position
Changes the position of the legend around the Pareto plot.
Legend Settings
Shows a window with options to edit legend settings such as the color, title position, and font of the legend text.
Show Cum Percent Axis
Shows or hides the cumulative percent axis on the vertical right axis.
Synchronize Y Axes
(Available only when the orientation is vertical.) Locks and unlocks the two Y axes. When this option is selected, zooming and panning of one axis is synchronized with the other axis.
Percent Scale
Sets the scale of the left Y axis to count or percent. A count scale is shown by default.
N Legend
Shows or hides the total sample size in the plot area.
Reorder Horizontal
(Available only when a grouping variable is specified.) Reorders horizontally grouped Pareto plots.
Reorder Vertical
(Available only when a grouping variable is specified.) Reorders vertically grouped Pareto plots.
Swap Group Orientation
(Available only when a grouping variable is specified.) Swaps the horizontal and vertical groups in the Pareto plot. If only one group is specified, the orientation of the plot is changed.
Ungroup Plots
Separates grouped Pareto plots when there are two or more groups.
Selected Causes
Shows a submenu of options to change the bars in the Pareto plot. These options are also available with a right-click anywhere in the plot area.
Combine Causes
(Available only if at least two bars are selected in the Pareto plot.) Combines selected bars into a single cause bar.
Separate Causes
Separates selected bars into their original component bars.
Move to First
Moves one or more highlighted bars to the left (first) position.
Move to Last
Moves one or more highlighted bars to the right (last) position.
Colors
Shows the colors palette for coloring one or more highlighted bars.
Markers
Shows the markers palette for assigning a marker to the points on the cumulative percent curve, when the Show Cum Percent Points command is in effect.
Label
Displays the bar value at the top of all highlighted bars.
Subset
Creates a subset data table from the selections in the Pareto Plot. If nothing is selected in the Pareto plot, all of the data from the plot is included in the data table.
