Fit Group reports contain results of multiple models that can be explored jointly in a profiler. To do this, launch a profiler from the Fit Group red triangle menu. This enables different Y’s to be profiled in the same profiler. Profilers for the individual Y’s can still be used in the respective Fit Model reports.
Fit Group reports are created in two ways. In some modeling platforms, when models are fit to multiple Y’s, the results are combined into a Fit Group report. Fit Group reports are also created when a By variable is specified for a Stepwise analysis. This allows for the separate models to be profiled in the same Profiler.
The Fit Group scripting command can be used to fit models in different platforms, and profile the individual models in the Profiler. See “Fit Group” in the Scripting Guide.
