To compute power, the Oneway platform uses the noncentral F distribution. The formula (O’Brien and Lohr 1984) is defined as follows:
Power = Prob(F > Fcrit, ν1, ν2, nc)
where:
F is distributed as the noncentral F(nc, ν1, ν2) and Fcrit = F(1-α, ν1, ν2) is the 1 - α quantile of the F distribution with ν1 and ν2 degrees of freedom.
ν1 = r - 1 is the numerator df.
ν2 = r(n - 1) is the denominator df.
n is the number per group.
r is the number of groups.
nc = n(CSS)/σ2 is the noncentrality parameter.
is the corrected sum of squares.
μg is the mean of the gth group.
μ is the overall mean.
σ2 is estimated by the mean squared error (MSE).
