This chapter describes how to customize JMP menus and toolbars to show only the commands that you need. For example, you might assign a shortcut key to the Run Script command.
Customizing JMP also lets you set up JMP for groups with special interests. If one group does not design experiments, you could remove DOE from the JMP menu.
Note: When you upgrade to JMP 18 Subscription, changes to preferences are maintained.
