Welcome to JMP > Learn about JMP > Documentation PDF Add-in
Publication date: 07/08/2024
You can download and install the JMP documentation add-in. The documentation add-in contains an individual PDF of each document in the JMP library and the JMP Documentation Library file. The JMP Documentation Library file is one PDF file that contains the individual book PDF files. It allows users to search all books in a single PDF file, similar to the JMP Online Help.
When installed, the documentation add-in adds the Documentation PDFs option to the Help menu and installs the PDF files on your machine. This enables you to access the documentation locally by selecting Help > Documentation PDFs. Download the available documentation add-ins from https://www.jmp.com/doc-addin.
The following table describes the purpose and content of each document in the documentation add-in.
Document Title
Document Purpose
Document Content
Provide one PDF of the other individual book PDF files.
Includes all the JMP documentation in one PDF.
Discovering JMP
If you are not familiar with JMP, start here.
Introduces you to JMP and gets you started creating and analyzing data, and sharing your results.
Using JMP
Learn about JMP data tables and how to perform basic operations.
Covers general JMP concepts and features that span all of JMP, including importing data, modifying columns properties, sorting data, and using workflow builder.
Basic Analysis
Perform basic analysis using this document.
Describes the following Analyze menu platforms:
Distribution
Fit Y by X
Tabulate
Text Explorer
Covers how to perform bivariate, one-way ANOVA, and contingency analyses through the Analyze > Fit Y by X platform. Also addresses how to approximate sampling distributions using bootstrapping and how to perform parametric resampling with the Simulate platform.
Essential Graphing
Find the ideal graph for your data.
Describes the following Graph menu platforms:
Graph Builder
Scatterplot 3D
Contour Plot
Bubble Plot
Parallel Plot
Cell Plot
Scatterplot Matrix
Ternary Plot
Treemap
Chart
Overlay Plot
The book also covers how to create background and custom maps.
Profilers
Learn how to use interactive profiling tools, which enable you to view cross-sections of any response surface.
Covers all profilers listed in the Graph menu. Analyzing noise factors is included along with running simulations using random inputs.
Design of Experiments Guide
Learn how to design experiments and determine appropriate sample sizes.
Covers all topics in the DOE menu.
Fitting Linear Models
Learn about Fit Model platform and many of its personalities.
Describes the following personalities, all available within the Analyze > Fit Model platform:
Standard Least Squares
Stepwise
Generalized Regression
Mixed Model
Generalized Linear Mixed Model
MANOVA
Loglinear Variance
Nominal Logistic
Ordinal Logistic
Generalized Linear Model
Learn about additional modeling techniques.
Describes the following platforms in the Analyze > Predictive Modeling menu:
Neural
Partition
Bootstrap Forest
Boosted Tree
K Nearest Neighbors
Naive Bayes
Support Vector Machines
Model Comparison
Model Screening
Make Validation Column
Formula Depot
Describes the following platforms in the Analyze > Specialized Modeling menu:
Fit Curve
Nonlinear
Functional Data Explorer
Gaussian Process
Time Series
Time Series Forecast
Matched Pairs
Describes the following Analyze > Screening menu platforms:
Explore Outliers
Explore Missing Values
Explore Patterns
Response Screening
Predictor Screening
Association Analysis
Process History Explorer
Multivariate Methods
Learn how to analyze several variables simultaneously.
Describes the following Analyze > Multivariate Methods menu platforms:
Multivariate
Principal Components
Discriminant
Partial Least Squares
Multiple Correspondence Analysis
Structural Equation Models
Factor Analysis
Multidimensional Scaling
Multivariate Embedding
Item Analysis
Describes the following Analyze > Clustering menu platforms:
Hierarchical Cluster
K Means Cluster
Normal Mixtures
Latent Class Analysis
Cluster Variables
Quality and Process Methods
Learn about tools for evaluating and improving processes.
Describes the following Analyze > Quality and Process menu platforms:
Control Chart Builder and individual control charts
Measurement Systems Analysis (EMP and Type 1 Gauge)
Variability / Attribute Gauge Charts
Process Screening
Process Capability
Model Driven Multivariate Control Chart
Legacy Control Charts
Pareto Plot
Diagram
Manage Limits
OC Curves
Learn to evaluate and improve reliability in a product or system and analyze survival data for people and products.
Describes the following Analyze > Reliability and Survival menu platforms:
Life Distribution
Fit Life by X
Cumulative Damage
Fatigue Model
Recurrence Analysis
Repeated Measures Degradation
Destructive Degradation
Reliability Forecast
Reliability Growth
Reliability Block Diagram
Repairable Systems Simulation
Survival
Fit Parametric Survival
Degradation
Fit Proportional Hazards
Consumer Research
Learn how to study consumer preferences and create better products and services.
Describes the following Analyze > Consumer Research menu platforms:
Categorical
Choice
MaxDiff
Uplift
Multiple Factor Analysis
Genetics
Learn how to analyze your genetic data to simulate a breeding program to predict the optimum genetic crosses to make.
Describes the following Analyze > Genetics menu platforms:
Marker Statistics
Marker Simulation
Scripting Guide
Learn about the powerful JMP Scripting Language (JSL).
Covers a variety of topics, such as writing and debugging scripts, manipulating data tables, constructing display boxes, and creating JMP applications.
JSL Syntax Reference
Learn about the JSL function arguments and messages.
Includes syntax, examples, and notes for JSL commands.
Keyboard Shortcuts
Learn how to use your keyboard to quickly navigate JMP and complete tasks.
Includes commands and the corresponding keystrokes for Windows and macOS.
Menu Descriptions
Learn what items are in the menus in JMP.
Describes the menu options for Windows and macOS.
