Description
Asset Framework path of the attribute to import. This can be a single path or multiple paths. The list of paths can be a JSL List, allowing the set of paths to be placed in a list variable.
Description
Determines how values that occur near the start and end time boundaries are treated.
Description
Optional end time of the series to import. Default value is "*" (now).
Description
An optional filter expression using PI Server’s filter expression syntax.
Description
Sampling interval in AFTimeSpan format. The default is "1h".
Description
Number of intervals to fetch. Default is 24.
Description
Sets the maximum number of values to retrieve. The default is 5000.
Description
Specifies whether to retrieve attribute status, which is stored in an additional column. This column, named "<attribute-name> status", uses a Multiple Response property with Value Labels to display the status as a set of the values: "Good," "Questionable," "Substituted," and "Annotated." This option is disabled by default.
Description
Specifies the time series type. The default value is "raw".
Description
Stacks attributes with the same name into a single column, and creates stacking columns for the common elements in their paths.
Description
(Optional) Specifies the start time of the series to import. The default value is "*-1d" (24 hours ago).
Description
(Optional) Specifies the synchronization time that sets the starting point from which interval boundaries are calculated.
Description
Determines how values that occur near the start and end time boundaries are treated. The default value is "inside".
Description
Cancels the import operation after no data has been received for the given number of seconds. A negative value directs the operation to wait for the default amount.
Description
(Optional) This flag indicates whether the start time and end time parameters are based on UTC. The default value is 0 (false).
