Publication date: 07/08/2024
JMP Tooltips
JMP provides descriptive tooltips (or hover labels) when you hover over items, such as the following:
menu or toolbar options
labels in graphs
text results in the report window (move your cursor in a circle to reveal)
files or windows in the Home Window
code in the Script Editor
Tip: On Windows, you can hide tooltips in the JMP Preferences. Select File > Preferences > General and then deselect Show menu tips. This option is not available on macOS.
