Publication date: 07/08/2024
Model Comparisons
The Model Comparisons section of the Fatigue Model report appears after you have fit at least one model. This section contains information about the data scaling that is used for calculating the model comparison statistics, as well as a table of the fitted models.
Note: The model comparison statistics, -LogLikelihood and AIC, are based on scaled data. This is the only place in the Fatigue Model where reported statistics are based on scaled data. Using scaled data does not affect model comparisons, so it is appropriate to use scaled data in this section. For more information about the data scaling, see Meeker et al. (2022).
The model comparison table contains the following columns:
Model Specified for
The category of the model. The Box-Cox Loglinear Sigma and Basquin (Inverse Power) models specify the fatigue-life distribution and then derive the fatigue-strength distribution; they are designated as Fatigue Life in this column. The remaining models specify the fatigue-strength distribution and then derive the fatigue-life distribution; they are designated as Fatigue Strength in this column.
Model Relationship
The type of model.
Model Distribution
The distribution used in the model.
N Parm
The number of parameters in the model.
-LogLikelihood
The negative log likelihood value for the model. Smaller values indicate a better fit. See Likelihood, AICc, and BIC in Fitting Linear Models.
AIC
The Akaike Information Criterion (AIC) value for the model. AIC is computed as 2LogLikelihood + 2k, where k is the number of fitted parameters in the model. Smaller values indicate a better fit.
Model Comparisons Report Options
There are three buttons located above the table that enable you to remove selected models, undo the last action, or redo the last undone action.
The Model Comparisons red triangle menu contains the following option:
Close All Individual Reports
Closes the outline nodes for all of the fitted model reports.
