Scripting Guide > Scripting Platforms
Publication date: 07/08/2024
Scripting Platforms
Create, Repeat, and Modify Analyses
If you run the same analysis frequently, you can script it to automate the process. Anyone can then run the script, ensuring the same results every time. To get started, perform your analysis interactively as you normally would with JMP, and then save a script that re-creates that analysis. You can modify the script to further customize it.
Figure 10.1 Typical Workflow for Scripting Platforms
This chapter is about scripting platforms, not reports. Platform object references and report object references receive different types of JSL messages. Platforms can run tests, draw plots, and so on. Reports can copy pictures, select display boxes, or close outline nodes. To learn about scripting reports, see the section Structure of JMP Reports.
Tip: For additional scripting help, see the JMP Scripting Index (select Help > Scripting Index) and the JSL Syntax Reference.
Contents
Example of Scripting a Platform
Send Messages to a Platform
Conventions for JMP Messages and Arguments
Send Multiple Messages
Find Messages for Objects
Interpret the Show Properties List
Send Messages to an Object
Specify Which Columns to Analyze
Create Column References
Specify Multiple Column Names at Once
Enable Users to Specify Columns
Specify a By Variable
Filter by Value Using a Where Statement
Enable User Input in JMP Platforms
Execute Embedded Red Triangle Options
Make the Platform Analysis Invisible
Save Platform Settings as a Platform Preset
Apply a Platform Preset to a Data Table
Specify Report Titles
Scripting Considerations by Platform
Categorical Scripts
Control Chart Builder Scripts
Distribution Scripts
DOE Scripts
Fit Model Scripts
Formula Depot Scripts
Graph Builder Scripts
Partial Least Squares and PLS Scripts
Process Capability Scripts
Scatterplot 3D Scripts
Text Explorer Scripts
Explore Outliers Scripts
