DRAFT help
Publication date: 09/20/2024
Add Analyses to a Journal
If you perform another analysis, you can add the results of the analysis to the existing journal.
1. With a journal open, select Analyze > Distribution.
2. Select profit/emp and click Y, Columns.
3. Click OK.
4. Select Edit > Journal. The results are appended to the bottom of the journal.
