DRAFT help
This section contains examples using the Workflow Builder:
• Example of Creating a Workflow from the Log History
• Example of Creating a Workflow with a Step Setting
• Example of Adding to a Workflow from the Enhanced Log
• Example of a Workflow with an If/Else Statement
• Example of a Workflow with a For Each Loop
