DRAFT help
Basic Analysis > Bootstrapping
Publication date: 09/20/2024
Bootstrapping
Approximate the Distribution of a Statistic through Resampling
Bootstrapping is a resampling method for approximating the sampling distribution of a statistic. You can use bootstrapping to estimate the distribution of a statistic and its properties, such as its mean, bias, standard error, and confidence intervals. Bootstrapping is especially useful in the following situations:
The theoretical distribution of the statistic is complicated or unknown.
Inference using parametric methods is not possible because of violations of assumptions.
Note: Bootstrap is available only from a right-click in a report. It is not a platform command.
Figure 11.1 Bootstrapping Results for a Slope Parameter
Contents
Overview of the Bootstrapping Feature
JMP Platforms that Support Bootstrapping
Example of Bootstrapping
Bootstrapping Window Options
Stacked Bootstrap Results Table
Unstacked Bootstrap Results Table
Analysis of Bootstrap Results
Additional Example of Bootstrapping
Statistical Details for Bootstrapping
Statistical Details for Fractional Weights
Statistical Details for the Bias-Corrected Percentile Intervals
