DRAFT help
Build a covering array design by selecting DOE > Special Purpose > Covering Array.
The covering array design updates as you work through the design steps.
• Factors
• Restrict Factor Level Combinations
• Design
• Metrics
• Output Options
• The Covering Array Data Table
