DRAFT help
Basic Analysis > Contingency Analysis > Contingency Analysis Reports > Cochran Armitage Trend Test Report
Publication date: 09/20/2024
In the Contingency platform, the Cochran Armitage Trend Test option tests for trends in the binomial proportions across the levels of a single variable. This test is appropriate only when one variable has two levels and the other variable is ordinal. The two-level variable represents the response, and the other represents an explanatory variable with ordered levels. The null hypothesis is the hypothesis of no trend, which means that the binomial proportion is the same for all levels of the explanatory variable. See Example of the Cochran Armitage Trend Test.
Note: The test statistic and significance probabilities (p-values) given in this test are approximate. An exact version of the trend test is also available.
