DRAFT help
Publication date: 09/20/2024
Color Cells in Data Tables
You can select one or more data table cells and change the color to highlight a specific value. Right-click the cell or cells, select Color Cells, and select a color. To remove color from cells, select the cells, right-click, and select Clear Color.
