DRAFT help
Publication date: 09/20/2024
Combined Model Parameter Estimates
The Combined Model Parameter Estimates report lists the terms in the final model for a definitive screening design. The report includes standard least squares estimates, standard errors, t ratios, and p-values for model terms. The RMSE and model degrees of freedom are also reported.
Below the report are buttons that construct or run the combined model.
Figure 9.10 Combined Model Parameter Estimates ReportĀ
Make Model
Creates a model for the Fit Model window containing the model terms in the Combined Model Parameter Estimates report and the response specified for the Fit Definitive Screening analysis. The Standard Least Squares personality is specified.
Run Model
Runs a standard least squares fit for the model terms in the Combined Model Parameter Estimates report and the response specified for the Fit Definitive Screening analysis.
