DRAFT help
Design of Experiments Guide > Compare Designs > Compare Designs Report
Publication date: 09/20/2024
The Compare Designs report consists of a Reference Design section and a Design Evaluation section. The Compare Designs report uses the column names from the reference design.
Changes that you make in the Reference Design Model and Alias Terms sections are updated in the Design Evaluation section.
This section describes the Reference Design, Factors, Model, and Alias Terms sections. See Design Evaluation in the Compare Designs Platform for a description of the Design Evaluation sections.
