DRAFT help
Profilers > Contour Profiler
Publication date: 09/20/2024
Contour Profiler
Explore Contours of Responses across Two Factors
The Contour Profiler shows plots of response contours for two factors at a time. Multiple contour plots for different combinations of factors can be viewed at the same time. The interactive contour profiling facility is useful for optimizing response surfaces graphically.
Figure 4.1 Contour Profiler Example
Contents
Overview of the Contour Profiler
Example of the Contour Profiler
Launch the Contour Profiler Platform
The Contour Profiler Report
Factor Settings and Controls
Response Settings and Controls
Contour Profiler Platform Options
Constraint Shading Settings
Additional Example of the Contour Profiler
