DRAFT help
Quality and Process Methods > Control Chart Builder > Control Chart Builder Options > Control Chart Builder Right-Click Axis Options
Publication date: 09/20/2024
The following options are available when you right-click the vertical axis of a control chart.
Remove Graph
Removes the entire graph.
Remove
Removes a variable.
Note: If there is more than one chart type on the graph, a submenu listing the different charts is displayed. You can select which chart to remove.
For more information about the Axis Settings, Revert Axis, Add or Remove Axis Label, Save to Column Property, and Edit options, see “Customize Axes and Axis Labels in Graphs” and “Extend Divider Lines and Frames for Categorical Axes” in Using JMP.
