DRAFT help
Publication date: 09/20/2024
Cumulative Damage
Model Product Deterioration with Variable Stress over Time
Cumulative damage models, which include step-stress models, enable you to analyze an accelerated life test where the stress levels might be changed over time. The stress can be applied by many different forces, such as load, temperature, or pressure. A typical cumulative damage experiment consists of multiple test units. Each unit has an initial stress level, and the stress level can be changed throughout the experiment. The response is the failure time or time-to-event. The platform plots the failure events and enables you to fit multiple distributions to your data.
Figure 5.1 Example of Cumulative Damage ReportĀ
Contents
Overview of the Cumulative Damage Platform
Example of the Cumulative Damage Platform
Launch the Cumulative Damage Platform
Time to Event
Stress Pattern
The Cumulative Damage Report
Event Plot
Stress Patterns Report
Model List
Model Results
Cumulative Damage Platform Options
Stress Patterns Option
Additional Example of the Cumulative Damage Platform
