DRAFT help
Using JMP > Save and Share Your Data > Create Journals > Customize Items in Journals
Publication date: 09/20/2024
To click and drag journal items to different positions, select the selection tool (Image shown here), select the item, and then drag the item to the new position. A line indicates where you can drag the item.
To adjust text wrapping, right-click the text and select Set Wrap. Enter the number of desired pixels per line and click OK. To apply the wrap to all text items, select Set Wrap, select Extend this to other text boxes, and then click OK.
To modify a plot axis, double-click or drag the axis. See “Customize Axes and Axis Labels in Graphs”.
To add text or shapes anywhere in the report, use the drawing tools (Annotate, Line, Polygon, and Simple Shape). For more information about the drawing tools, see “Add Annotations and Shapes to JMP Reports and Graphs”.
To resize plots and graphs, do one of the following:
Click and drag the edge.
Right-click the plot or graph, and then select Size/Scale > Frame Size. See “Resize Graphs”.
To modify the format of a numeric column, you edit the Properties pane for the display box. See “Change the Format of Numeric Columns”.
