DRAFT help
Publication date: 09/20/2024
Data Format
In the Bivariate platform, your data can consist of columns of unsummarized or summarized data:
Unsummarized data
There is one row for each observation and columns for X and Y values.
Summarized data
Each row represents a set of observations with common X and Y values. The data table must contain a frequency column that contains the counts of observations for each row. Enter this column as Freq in the launch window.
Note: The Fit Y by X launch window accommodates columns with continuous, ordinal, and nominal modeling types. The Bivariate platform is launched for all pairs of Y, Response and X, Factor columns that have the continuous modeling type. The Fit Y by X launch window launches the Oneway, Contingency, or Logistic platforms for other column type combinations.
