DRAFT help
Profilers > Surface Plot > Surface Plot Platform Options > Dependent Variables Options
Publication date: 09/20/2024
In the Surface Plot report, the Dependent Variables section contains the following red triangle menu options:
Formula
Shows or hides the Formula column in the Dependent Variables controls.
Surface
Shows or hides the Surface column in the Dependent Variables controls.
Points
Shows or hides the Point Response Column column in the Dependent Variables controls.
Response Grid
Shows or hides the Grid controls.
