DRAFT help
Publication date: 09/20/2024
Design Generation
In the Screening Design platform, when you construct a main effects screening design, you can specify the number of runs in the Design Generation section. To generate the design, click Make Design.
Number of Runs
Select an option to specify the number of runs for your design.
Minimum
A lower bound on the number of runs necessary to avoid failures in design generation. When you select Minimum, the resulting design is saturated. There are no degrees of freedom for error.
Note: If you select the Minimum number of runs, there is no error term for testing. You cannot test parameter estimates. This choice is appropriate only when the cost of additional runs is prohibitive.
Default
Suggests the number of runs. This value is based on heuristics for creating a balanced design with at least four runs more than the Minimum number of runs.
User Specified
Specify the number of runs that you want. Enter that value into the Number of Runs text box. This option enables you to balance the cost of additional runs against the potential gain in information.
Design
For a main effects screening design, the Design section shows the runs. To change the run order for your design table, you can select Run Order options in the Output Options section before generating the table.
