DRAFT help
Publication date: 09/20/2024
Disconnect from the CAS Server
CAS Disconnect() disconnects from the current CAS server and optionally terminates the session. By default, the session is terminated when disconnected.
CAS Disconnect(<"Terminate"|"NoTerminate">);
